Bonjour à tous,
Mon choix se porte vers 2 VTT:
- Commencal META HT CRMO 650B année 2014
FRAME New 2014 META CRMO 650b, CrMo light double butted, integrated hanger
FORK FOX 32 650b float evolution o/c, 150mm qr15
HEADSET semi integrated, tapered zs44/44, 1”1/8 lower washer ball retainer
STEM ALPHA, alloy 2014 forged, 60mm, 0° rise, ø31,8mm
BAR ALPHA, alloy 6061db, 0.75”rise, 750mm, ø31,8mm
GRIPS COMMENCAL 2014 lock on, outside ø30mm, soft compound
BRAKES New FORMULA c1, 180mm/180mm, with X7 matchmaker
SHIFTERS SRAM x7 2x10 speed
FRONT MECH SRAM x5 2 speed
REAR MECH SRAM x7 type 2 10 speed
BOTTOM BRACKET SRAM GPX 92mm sealed bearings
CRANKS SRAM S1000 gxp 24/38t, 170mm xs/s, 175mm m/l/xl
CHAIN YABAN SH10C, with quick link connector
CASSETTE SRAM pg1030 11-36t
RIMS 650b 32h double wall, 26,5mm, pin joint, disc version
HUBS 32h, sealed bearings, steel cassette body
SPOKES Stainless steel 1,8mm black - brass 12mm black, lockseal
TIRES MAXXIS High Roller II EXO 650bx2,3 front, ardent 650b x 2.25” EXO rear, 60tpi folding bead
SEATPOST KINDSHOCK ETEN remote, 100mm travel 30,9x385mm
SADDLE COMMENCAL META, CrMo rails
COLOUR Matt Black Finish
BIKE WEIGHT(kg/lbs) 13,50
- Commencal META HT AM RACE 27,5 année 2015
Cadre 2015 META HT AM 650b, aluminium 6061, triple butted
Fourche ROCKSHOX Revelation RL Solo Air 150 mm, pivot conique, axe 15 mm
Jeu de direction NECO semi integré, conique ZS44/56, adaptateur 1"1/8
Potence ALPHA, aluminium 2014 forgé, 60 mm, Ø 31,8 mm
Cintre ALPHA, aluminium 7075 double butted, 20 mm rise, 750 mm, Ø 31,8mm
Grip COMMENCAL lock on, Ø30 mm, soft compound
Freins FORMULA CR3 180 mm/180 mm, matchmaker
Commandes de vitesses SRAM X7 2 x 10 vitesses
Dérailleur avant SRAM X5, direct mount, 2 plateaux
Dérailleur arrière SRAM X9 10 vitesses, type II
Boîtier de pédalier SAMOX GXP BB 68 mm, roulement scellés
Pédalier SAMOX, 2 pièces, 24/38 dents, manivelles 170 mm (S) ou 175 mm (M/LXL)
Chaîne KMC X10 10 vitesses
Cassette SRAM PG1020 11-36 dents
Jantes ALPHA 650B, 32 rayons, double paroi, tubeless ready
Moyeux ALPHA 32 rayons, roulements scellés, QR
Rayons CN acier, 1,8 mm
Pneus Avant : MAXXIS Ardent 2,4", 60 tpi, tringle kevlar / Arrière : MAXXIS Ardent 2,25", 60 tpi, tringle kevlar, flancs EXO
Tige de selle KINDSHOCK Eten, 100 mm, 385 mm x 31,6 mm, levier KGP
Selle ALPHA, rails chromoly
Poids (fabricant) 12,1 kg
Lequel choisir?
Merci.
Lequel choisir?
Merci.
inscrit le 26/06/15
2 messages
